It is currently Wed May 20, 2026 6:55 am
 Post subject: Trans Troubles
PostPosted: Mon Jul 16, 2007 6:56 pm
A couple days ago I noticed my Dart was having to rev really high to get change gears ( it's an auto) It didn't do it all the time but when it was really hot it would. Then it slipped out of gear at a stop light!! I check t he trans and it was at the "Add a pint" level. I've since added some and it seems to be fine. Do you think I may of done any real damage to the tranny? The dip stick smells just a little burnt, but not near as bad as my daily driven oldsmobile! :D There doesn't seem to be any visible leaks on the tranny so I'm a bit concerned.
Other than that now it shifts well and runs strong. I dont' have any other problems than when I started (Fuel, radiator and brake leak!) :D
In the even this trans goes the way of the buffalo how hard would it be to find a new one? It's in a 64 dart (push button auto) Would that be the 904 tranny?
Any info I could get would be great![/img]
PostPosted: Mon Jul 16, 2007 9:10 pm
A rebuild is down the road if it is acting normal now, but yes burn smelling
fluid is not good. Brown fluid is worse, and if it has specs of black- even worse.
But if you keep a eye on your fluid level you should get some time
out of it. I have babied one for many years. Filter change and band
adjustment may extend its life.
Even the best auto trans can have miner leaks and loose fluid
over time. Most of the 904's and 727's do not like to be down
any more than a pint, to quart, of fluid or they will start slipping.
If you got burnt smelling fluid I would not recommend a compleat
fluid change if the fluid is the least bit off color from red/pink, just what you need to change the filter.
The burnt smell comes from bands and clutchs inside that have gotten
hot and lost surface. There may be some damage, it just depends
on how bad they were heated and for how long.
99.9% chance of a having a 904 in a 64 Dart.
Some shops will not do the early 904, call around or find a local guru
mopar guy that does it (the guru may save some money when
the time comes).......
My $.02
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
PostPosted: Tue Jul 17, 2007 2:47 am
Hey thanks for the info!
The fluid in the Tranny has always been nice and red, even when I got the car. It's shifts like a champ when working properly and has always gone pretty swift when I lay down on it.
Now this band adjustment I hear talk of, how does this work? Would it be beyond this novice's scope?
I think on lunch today I'm going to make some transmission calls maybe I could get a rough idea what a 904 would be to rebuild. It's a great car and I wouldn't mind putting more back into it..
PostPosted: Tue Jul 17, 2007 4:14 pm
SSRN National Champion
Just a personal thought I would stay away from national chain trans shops. Like aam ect and mr trans. They will usually quote you about 1200 dollars for a rebuild. Find a Mom and Pop shop that has been in business for say 40 years. I know that is hard to find ask some racers where to go. Me and Dale Rose And Norm Foster have our transmissions built by the same person that has been doing this for over 40 years. Mine has been in 7 years Dales about the same and Norms about two years. Our Transmissions take the most punishment you can put on one. Great transmission man pricless rebuilds about 350 dollars. Thanks Ron Parker :D
I Did Not Get Where Im At Because Im Good I Had Slanted Friends
PostPosted: Tue Jul 17, 2007 7:41 pm
sounds like Rons got it down.....
If you have a FSM, follow it, if not get one, you really should have
one for your car. They can be had for fair price on CD these days....
Band adjustment needs a inch pounds tork wrench to do right (not foot pounds).
One band adjusts on the outside of the case, the other when the
pan is off. I would advise you get someone to help you out
that has done it before so it gets done right, at least the frist
time though it.
Not building pianos here, pretty easy for a do-it-your self'er
but it does need to be right.
Filter swap is pretty easy to do. The only hard part is getting the
gasket to fit right and not 'over' torking the pan once the filter
is in place...... over tork the pan and the gasket will push out
and leak.
62 D100 225 3sp lwb
Old iron or no iron
