It is currently Tue May 26, 2026 3:06 pm
PostPosted: Sat Jul 28, 2007 6:02 pm
Can we see some picts on how the brackets are made and how they mount so i can fabricate to look origional?
PostPosted: Sun Jul 29, 2007 7:12 am
I don't have a picture, but the bracket is fairly easy to fabricate. The factory one is a "U" shaped piece that bults to where the P/S pump would. You can use the standard adjuster strap and just cut it to length and redrill the hole. It now goes to a water pump bolt instead of the head.
