It is currently Wed Nov 18, 2026 10:15 am
PostPosted: Fri Jul 13, 2007 7:37 pm
Remember, stock /6 & 80k miles cept for 340 valve springs.
234.49 rear wheel HP/ 309.12 max torque / 20.02 max psi/ 11.4 AFR
Link to original
http://www.slantsix.org/forum/viewtopic.php?t=23348
PostPosted: Fri Jul 13, 2007 9:50 pm
Whoa ! That's a spicey meatball !!Have to get me one o' them hair dryers!!
PostPosted: Fri Jul 13, 2007 11:26 pm
Way to go Shaker!!!
Chris'
Autobody
Restoration
Service
PostPosted: Sat Jul 14, 2007 5:28 am
Congratulations! I can't wait to get mine running.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Sat Jul 14, 2007 5:44 am
Thanks for the update! That's very cool. I am really glad to know things are working out. You should feel a real sense of accomplishment there. If you are going racing, share a timeslip with us.
Sam
PostPosted: Sat Jul 14, 2007 7:30 am
Unfortunatly, my weekends are booked for a while so I won't be able to make it to the track. I think the motor has more in it...just need to find it. (without opening it up, cam, porting etc). The air fuel was real stable. It settled between 11.2-11.4 for the whole run. Just wish I had time to do a few plug readings...I ran out of time because I had to be somewhere (the guy in front of me took almost 4 hours)
Eventually I'd like to FI it....Sam, you're the lead on that!!
PostPosted: Sat Jul 14, 2007 10:48 am
Wow, that's some good carb tuning.
PostPosted: Wed Jul 18, 2007 5:21 pm
[quote="Shaker223"]Remember, stock /6 & 80k miles cept for 340 valve springs.
Seen lotso mega elaborate NA Slant buildups over the years , almost none make these #s ...Looks like a buncho junk (& a little common sense ) beats a buncho money anyday!!
Boost ON Brutha !!
PostPosted: Wed Jul 18, 2007 8:39 pm
Thanks!!! Like you said, Just trying to make the junk run ...needs a header and a better exhaust after the turbo.
