It is currently Wed May 13, 2026 10:07 pm
 Post subject: Converter interchange
PostPosted: Tue Jul 24, 2007 11:52 am
I have 2 transmissions, a 74 904 318 tranny,and a 1973 slant 6 tranny. Will the 904 stall converter from the 318 car work with the slant tranny as far as fitment??
Barret-Jackson: Ruining the car hobby for everyone!
PostPosted: Tue Jul 24, 2007 12:08 pm
Yes, but what do you mean by a "stall converter"? All converters have a stall speed when used behind an engine of given characteristics. There are high-stall and low-stall converters, but no such thing as a "stall converter".
PostPosted: Tue Jul 24, 2007 12:26 pm
I meant to say the converter is a 2600 stall converter. Sorry :x
PostPosted: Tue Jul 24, 2007 1:08 pm
Feather,
The converter will interchange, or, yes you can run that converter on either trans.
You should know that if it stalls at 2600 on a 318, it will almost certainly stall between 1600-2100 on a Slant - been there, done that... It may not stall any higher than a stock Slant converter (usually 1700-1800).
PostPosted: Tue Jul 24, 2007 2:24 pm
Thanks for the info Lou, Thats kinda what I figured. But I think I may try it just because and see what happens
