It is currently Mon May 18, 2026 10:10 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
PostPosted: Thu Jul 19, 2001 2:13 am
Hi all,
I am planning to install aftermarket disc brakes on my /6 63 Dart. I won't be able to use my 13 inch wheels.
I am looking for *any* 14 or hopefully 15 inch wheels for that car (it's got the 4 inch bolt pattern).
If anyone wants to clean out their garage, please let me know!
thx
KLT
klt@kevinleethomason.com
PostPosted: Thu Jul 19, 2001 10:26 am
: Hi all,
: I am planning to install aftermarket disc
: brakes on my /6 63 Dart. I won't be able to
: use my 13 inch wheels.
: I am looking for *any* 14 or hopefully 15 inch
: wheels for that car (it's got the 4 inch
: bolt pattern).
: If anyone wants to clean out their garage,
: please let me know!
"Aftermarket" Disc brakes...??, who is the manufacturer? Will they have the "5 on 4" small bolt pattern and the small center hole "register"?
If your plan is to used the 66-72 K.H. 4 piston, fixed caliper set-up, then you are "on target" looking for the "small lug" 14" or larger rims. If it is "aftermarket stuff", we need a bit more info.
PostPosted: Thu Jul 19, 2001 1:23 pm
Who is doing the aftermarket stuff? Do theier disks fit stock hubs? How much?
I have five steal 4 on 4 14" rims for you. Stock looking. they fit the KH setup. Where are you located?
You can get them in just about any wrecking yard though. Email me if you are near Oakland (give or take 70 miles) I would like $10 a peice, but would let them go for ......... (I havbe to ditch them)
: "Aftermarket" Disc brakes...??, who
: is the manufacturer? Will they have the
: "5 on 4" small bolt pattern and
: the small center hole "register"?
: If your plan is to used the 66-72 K.H. 4
: piston, fixed caliper set-up, then you are
: "on target" looking for the
: "small lug" 14" or larger
: rims. If it is "aftermarket
: stuff", we need a bit more info.
: DD
richard-c@e-d-a.com
PostPosted: Thu Jul 19, 2001 2:59 pm
Hi Doug!
The are from "Stainless Steel Brakes" - according to their website - they use the 5x4 inch bolt pattern, and are designed specifically for the car - they are supposed to be a bolt on for the car. They had better be for what they charge - see: <A HREF="http://www.stainlesssteelbrakes.com/pag ... odel=63</A>.
But if anyone has any spare K-H stuff laying around and wants to make some money by helping me do the conversion - I'd be happy to use real MP stuff rather than aftermarket.
: DD
PostPosted: Thu Jul 19, 2001 3:04 pm
Hi Richard!
I'm right across the Bay Bridge - I just sent an email to you...
k
: I have five steal 4 on 4 14" rims for you.
: Stock looking. they fit the KH setup. Where
: are you located?
: You can get them in just about any wrecking
: yard though. Email me if you are near
: Oakland (give or take 70 miles) I would like
: $10 a peice, but would let them go for
: ......... (I havbe to ditch them)
PostPosted: Sun Jul 22, 2001 2:33 am
: I saw a complete KH set up at Carlisle with rotors for $300, but then your looking at rebuiling everything.
