It is currently Tue May 19, 2026 11:46 am
 Post subject: 904 Trans
PostPosted: Fri Jul 27, 2007 4:21 pm
How much horsepower can the 904 trans handle?
Go for it, You live this life only once.
PostPosted: Fri Jul 27, 2007 4:51 pm
In stock form with the 3 disc clutches, not much. :(
With the V-8 clutches and 4 pinion planetaries, a lot. :lol:
None of the Slant racers use a 727 if that tells you anything. :D
 Post subject: 904
PostPosted: Tue Jul 31, 2007 7:00 pm
Everyone that I know that runs in stock class runs them.
Most all run low 12's to mid 11's so you are looking at 400 HP.
Some guys use a JW bell housing and put them behind big blocks too.
They have well over 500 HP.
IF the car is heavy (4000 lbs) I might be leary,, but who knows.
All of mine worked just as good as the 727.
