It is currently Sat Dec 27, 2025 1:49 pm
PostPosted: Sun Jul 29, 2007 9:54 am
Hello folks,
I am using a carbureted engine that has worked just fine with 1bbl, 2bbl and 390 and 500 cfm 4bbl carbs. Carbs are supplied with a new stock fuel pump through metal filter, up and over the valve cover in the suggested modification manner, through a new fuel pressure gage to carbs. Fuel is suupled through 5/16 braided steel line with AN fittings.
My fuel pressure is a steady 2 psi. Volume output matches FSM pump test in a jar. . I understand why FI guys want more pressure, but I have read in many places that the carbs, particularly 4bbl, need 4 to 7 psi. So what gives...why do so many mfgrs spec 4 to 7 for their carbs? I must be getting the volume needed at 2 psi because up to nearly 90 mph there is no fuel shortage, so I have long been more focused on volume than pressure. Sure I can up pressure by using a smaller diameter line, but to what end? What pressure on a stock fuel supply are others operating at?
rock
'64d100
PostPosted: Sun Jul 29, 2007 11:45 am
2 weeks ago a friend of mine replaced the fuel pump and got a weird pump that delivers 10 PSI :shock: but LESS volume than the older pump wich worked fine (I told him NOT to try'n repair something that's working, but! ) same line, same everything, long story short, fouled plugs, the ammount of pressure was causing the needle/float assy to be open all the time, permitting the pump to flood the engine at idle.
2 PSI at idle or in revs?
Juan Ignacio Caino
PostPosted: Sun Jul 29, 2007 12:27 pm
If you're getting the volume necessary but only seeing 2psi on the gauge, my best guess is an improperly-calibrated gauge. Factory spec on the slant-6 is 3-5 psi.
PostPosted: Sun Jul 29, 2007 12:32 pm
Is that flowing pressure or dead-headed with the needle closed? :shock:
Users browsing this forum: Ahrefs [Bot] and 25 guests
