| starting problems / fuel problems https://slantsix.org/forum/viewtopic.php?t=24280 |
| Author: | Jamakin [ Mon Jul 30, 2007 7:48 pm ] |
| Post subject: | starting problems / fuel problems |
Ok i have been having a problem with my slant starting since i got the car a year ago. After the car sits the fuel drains out of the fuel filter and thus makes it very hard to start and usually requires a few sprays of starter fluid to get it going. First i thought it was the fuel sending unit because it had a pin hole leak in it. I changed that and no good. It actually got worse. Now tonight I changed the fuel pump and still no good. Now this wasn't a new pump but one that i had around sitting on the shelf that i used to just test out a motor once. Anyways its still no good, it actually seems to be getting worse. After a few minutes now the fuel filter is completely empty. Any thoughts or suggestions?? |
| Author: | SlantSixDan [ Mon Jul 30, 2007 7:51 pm ] |
Put in a new fuel pump, do the fuel line mod including a new metal fuel filter, and replace the inlet needle and seat on your carburetor. |
| Author: | Jamakin [ Tue Jul 31, 2007 2:57 pm ] |
....last night when i walked away from the car the fuel filter was empty......to day when i got home from work i looked at it and it was full. I'm not sure what to make of that but the car started right up. That really doesn't make anysense to me. |
