It is currently Fri Nov 20, 2026 4:23 am
PostPosted: Mon Jul 30, 2007 7:48 pm
Ok i have been having a problem with my slant starting since i got the car a year ago. After the car sits the fuel drains out of the fuel filter and thus makes it very hard to start and usually requires a few sprays of starter fluid to get it going.
First i thought it was the fuel sending unit because it had a pin hole leak in it. I changed that and no good. It actually got worse. Now tonight I changed the fuel pump and still no good. Now this wasn't a new pump but one that i had around sitting on the shelf that i used to just test out a motor once. Anyways its still no good, it actually seems to be getting worse. After a few minutes now the fuel filter is completely empty.
Any thoughts or suggestions??
PostPosted: Mon Jul 30, 2007 7:51 pm
Put in a new fuel pump, do the fuel line mod including a new metal fuel filter, and replace the inlet needle and seat on your carburetor.
PostPosted: Tue Jul 31, 2007 2:57 pm
....last night when i walked away from the car the fuel filter was empty......to day when i got home from work i looked at it and it was full. I'm not sure what to make of that but the car started right up. That really doesn't make anysense to me.
Users browsing this forum: Bing [Bot], DuckDuckGo [Bot] and 7 guests
