It is currently Wed May 27, 2026 4:23 pm
PostPosted: Fri Aug 03, 2007 7:22 pm
Does any one make Stainless Steel Braided Hoses For the F body?
I think My Chung Sheng Brand ones are doing the Magic Check Valve Effect again...
Thanks, Greg
PostPosted: Mon Aug 06, 2007 7:07 am
I'm sure that if you check out Earl's you can find all the hoses and fittings you need Greg. :D
I have the setup for my '66 for whenever I get around to putting my Wilwoods on. Lines are pretty standard, just need a couple adapter fittings and you're good.
PostPosted: Mon Aug 06, 2007 7:06 pm
Thanks, Dennis, I will Look at Earl's Stuff Soon.
The only Other Stuff I could find at the Parts store was Bendix Hose, Which I might Try In the meantime to get my car going straight when I put on the Brakes.
 Post subject: braided hose
PostPosted: Tue Aug 07, 2007 4:43 pm
Greg, you got part of your question answered yourself.Stainless Steel Brake Corp. will have them. Yes Earl's plumbing too and that can be had at Jegs or Summit.Classic Tube also has kits too.
 Post subject: Brake hoses
PostPosted: Tue Aug 07, 2007 4:48 pm
Also try stopflex.com ( owned by Classic Tube ) 800-882-3711. If they don't have them they will make them for you..........
PostPosted: Wed Aug 08, 2007 7:18 pm
Thanks Romeo, I will look into that!! Greg
PostPosted: Fri Aug 10, 2007 8:04 pm
If u find anything on this subject I'd be interested too, including the one to the rear axle.
