Stainless Steel Braided Hoses
https://slantsix.org/forum/viewtopic.php?t=24327
Author:  Greg Ondayko [ Fri Aug 03, 2007 7:22 pm ]
Post subject:  Stainless Steel Braided Hoses
Does any one make Stainless Steel Braided Hoses For the F body?
I think My Chung Sheng Brand ones are doing the Magic Check Valve Effect again...
Thanks, Greg
Author:  slantzilla [ Mon Aug 06, 2007 7:07 am ]
I'm sure that if you check out Earl's you can find all the hoses and fittings you need Greg. :D
I have the setup for my '66 for whenever I get around to putting my Wilwoods on. Lines are pretty standard, just need a couple adapter fittings and you're good.
Author:  Greg Ondayko [ Mon Aug 06, 2007 7:06 pm ]
Thanks, Dennis, I will Look at Earl's Stuff Soon.
The only Other Stuff I could find at the Parts store was Bendix Hose, Which I might Try In the meantime to get my car going straight when I put on the Brakes.
Author:  Romeo Furio [ Tue Aug 07, 2007 4:43 pm ]
Post subject:  braided hose
Greg, you got part of your question answered yourself.Stainless Steel Brake Corp. will have them. Yes Earl's plumbing too and that can be had at Jegs or Summit.Classic Tube also has kits too.
Author:  Romeo Furio [ Tue Aug 07, 2007 4:48 pm ]
Post subject:  Brake hoses
Also try stopflex.com ( owned by Classic Tube ) 800-882-3711. If they don't have them they will make them for you..........
Author:  Greg Ondayko [ Wed Aug 08, 2007 7:18 pm ]
Thanks Romeo, I will look into that!! Greg
Author:  volaredon [ Fri Aug 10, 2007 8:04 pm ]
If u find anything on this subject I'd be interested too, including the one to the rear axle.
