It is currently Sun Nov 29, 2026 11:54 am
 Post subject: Transmission leaking.
PostPosted: Mon Aug 06, 2007 7:29 am
Noticed today that I had transmission fluid on the ground under the converter. The puddle was about a 12" diameter circle. I have also noticed a delay when shifting in to gear for the past 2 days. Fluid level is still in the aceptable range. I haven't really looked closely at it yet as I just saw the fluid this morning on my way out to work.
PostPosted: Mon Aug 06, 2007 12:20 pm
Oil on the ground and a delayed shift first drive of the day usually means the front pump bushing is worn.
