It is currently Sun Nov 22, 2026 8:14 am
PostPosted: Sun Aug 12, 2007 7:00 pm
Engine:
Here is the # found below the #1 spark plug: AL-HP-187431C
Here is the casting #: 2463430-15
Tranny :
A-904-G, and I found 3 serial # on it, one is 2464935 4 and the other are just above the pan: 2466119W 1552658, these last 2 have a space between them.
So what do these numbers have to say? :D
1965 Valiant Custom 200, 2dr hardtop, 225ci
1997 Monte Carlo, 3800 supercharged swap
1995 Lumina, 3.4 DOHC swap
PostPosted: Sun Aug 12, 2007 7:41 pm
Engine:
Means a 225 engine originally installed in a 1965 Canadian-built 111"-wheelbase Valiant. The 187431C may be part of your vehicle's VIN; I don't recall and my '65 Canadian FPC is far, far away from me.
Means a pre-'67 RG (225) engine block.
Tranny : 2466119
Means a 1965 A904G installed behind a 225 in an A-body.
All in all, sounds like you're working with the original engine and transmission.
PostPosted: Mon Aug 13, 2007 5:57 pm
Thanks Dan!
I checked but the 187431C is not part of my VIN, so I don't know what it could be.
Can I ask wich letter means what? I searched but didn't find :cry:
PostPosted: Mon Aug 13, 2007 6:30 pm
A: 1965
L: 111"-wheelbase Valiant
HP: High Performance (225 engine option rather than standard 170)
