It is currently Thu Nov 26, 2026 5:55 pm
PostPosted: Tue Aug 14, 2007 5:25 pm
I recently found a donor car for my smashed rear window and the car has front disc brakes. It's a '73 4-door and mine's a '70 4-door. I've already had my front end apart before, so that bit's a no-brainer, but I wonder what parts I ought to grab while I'm under there (I'm going to nab the UCAs, LCAs, Spindles, calipers, MC). Are there any parts I'm overlooking? I'm thinking about nabbing the engine and trans for a future rebuild, but we'll see what he wants for them first. Also, any problems you fellows can see with this swap? It should be a straight replacement, right?
Thanks in advance,
Nat
1970 four-door Dart, 225/A-904/2.45 gears. 0-60 in twenty three minutes!
 Post subject: The rear too...
PostPosted: Tue Aug 14, 2007 5:58 pm
Yep, you want the rear end also, since it will have the large bolt pattern that the discs have (you may get lucky and see if it's a 8 1/4" too...)...
You may also want to grab the wheels temporarily until you find an LBP set you really like...
PostPosted: Tue Aug 14, 2007 9:09 pm
Don't forget the drive shaft if you're changing the rear end.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Aug 15, 2007 5:25 am
Also, you can use the '70 LCAs; it's just the UCAs that are different. Unless you want to run a whole '73 K-member setup.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Wed Aug 15, 2007 6:40 am
Does He also need the Proportioning Valve?
Frank
73 Duster - Race Car
66 Dart Wagon - DD
178" FED
82 D150
All Slant powered
PostPosted: Wed Aug 15, 2007 5:15 pm
Thanks fellas. I'm going to scope it all out this weekend. I may just buy the whole car for the amount of stuff I want off it.
Thanks again,
Nat
