It is currently Sat Nov 28, 2026 1:00 pm
PostPosted: Thu Aug 23, 2007 12:10 pm
Just making sure i have all the tools ready to switch the third member at the track. Will i have to totally disassemble the brakes to get the axel to slide out far enuf or can i just remove the upper springs and the bar?
Thanks for any help!
TF
Even in moderation i am excessive!
PostPosted: Thu Aug 23, 2007 1:16 pm
No, you will not have to dis-assemble the brakes to swap center sections on an 8 3/4.
You will need an extra gasket and a few razor blades to scrape the old gasket off.
I will bring my special oil pump "can" to the Redding... getting the gear oil back in is the hardest part of the job.
PostPosted: Thu Aug 23, 2007 2:18 pm
Thanks Doc it sound like i am all ready to head up see ya there!
PostPosted: Thu Aug 23, 2007 3:20 pm
Axle tube seals and bearing retainer gaskets--
I almost always replace those too when I'm in a 8.75........
just depends on what the old ones look like.
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
PostPosted: Thu Aug 23, 2007 4:47 pm
6 Pack Dart
Doc;
you are trying to make it way too easy. I am still using the manual pump on the gallon jug. Oh well, guess I am still too old school or to lazy to find and put together what you described at the last Redding meet.
Looks like a lot of us will be swapping third members, Oh the fun.
