It is currently Thu Nov 26, 2026 6:56 pm
 Post subject: new bushings
PostPosted: Fri Aug 17, 2007 1:21 pm
my caster camber bushings are shot i am burning 2 tires a week on the front end does any body know where to get cheap reliable bushings
PostPosted: Fri Aug 17, 2007 3:00 pm
I'm assuming you mean the upper control arm bushings. Try you local Car Quest or NAPA store. They should still be available from either. You could go to NAPA's website and look them up to be sure. Check your lower control arm bushings as well as strut rod bushings as well since they are probably trash too.
Now, let's all argue over which brand an/or material is better than all the rest! Or, you could just do a search.
-James
 Post subject: bushings
PostPosted: Fri Aug 17, 2007 4:35 pm
Autozone part #FB256
