It is currently Mon May 11, 2026 9:16 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 5 posts ]
 Post subject: Overdrives
PostPosted: Tue Jul 24, 2001 2:51 pm
Ran onto an interesting site while surfing today---check it out:
<A HREF="http://www.gearvendors.com/index.html">http://www.gearvendors.com/index.html</A>
<A HREF="http://www.gearvendors.com/articles/hotrod/may00/index.html">http://www.gearvendors.com/articles/hotrod/may00/index.html</A>
---Red
 Post subject: Re: Overdrives
PostPosted: Tue Jul 24, 2001 6:13 pm
Those are great. I think you need a 727 if you use a MoPar auto trans. Cost around $2,000, but bullitproof and ought to last 200,000 miles before they need work, claimed to have been tested for 1,500 horsepower. They use sprage clutches like automatics so you can shift under full power.
Is there anything like this that doesn't cost so much ?
: Ran onto an interesting site while surfing
: today---check it out:
: <A HREF="http://www.gearvendors.com/index.html">http://www.gearvendors.com/index.html</A>
: <A HREF="http://www.gearvendors.com/articles/hotrod/may00/index.html">http://www.gearvendors.com/articles/hotrod/may00/index.html</A>
: ---Red
PostPosted: Tue Jul 24, 2001 6:19 pm
: Those are great. I think you need a 727 if you
: use a MoPar auto trans. Cost around $2,000,
: but bullitproof and ought to last 200,000
: miles before they need work, claimed to have
: been tested for 1,500 horsepower. They use
: sprage clutches like automatics so you can
: shift under full power.
: Is there anything like this that doesn't cost
: so much ?
According to the Gear vendors rep at the Mopar Spring Fling show, they are now making them for 904 automatics too.
madsenl@caltech.edu
PostPosted: Tue Jul 24, 2001 6:50 pm
That would be excellent, and an easier swap than the T-5 (which is where I'm looking because the G/V is way out of my budget ). The G/V unit is beefy and can handle pretty much any gasoline or light truck diesel motor - and requires no floorpan mods.
: According to the Gear vendors rep at the Mopar
: Spring Fling show, they are now making them
: for 904 automatics too.
: Lou
PostPosted: Wed Jul 25, 2001 5:17 pm
I e-mailed the company today, and was told they only make it for the 727.
