It is currently Sat May 16, 2026 1:09 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 8 posts ]
PostPosted: Tue Jul 24, 2001 3:32 pm
first off, let me apologize for using this slant 6 site for this question.
For anyone that might have similar experience.....the windows in my 65' valiant v100 keep getting fogged up. I'll clean them with window cleaner than they get fogged up again a few days later. Anyone know how to treat this?
Orionsax7@cs.com
PostPosted: Tue Jul 24, 2001 4:16 pm
I had this happen to me and it was the heater core leaking and spraying steam into the vents.
The other time I had this happen - I was driving semi and coming back from Minnesota in the middle of summer - it was around 100% humidity and I had the airconditioner going full bore because it was also around 95 degrees out and about 10 o'clock at night! The windows fogged up like crazy!!
Talk at ya later,
Dan
"I may be slow, but at least I'm not very fast!"
gramma@dm-ttech.net
PostPosted: Tue Jul 24, 2001 9:27 pm
Thanks for the info but i don't think those are the causes. My windows fog up slowly, over the course of a few days. And it happens more in the heat with the windows up, even when I'm not driving. I just heard something about vinyl fogging. What's that all about?
Orionsax7@cs.com
PostPosted: Tue Jul 24, 2001 9:40 pm
I vote for the heater core leaking / weeping. The antifreeze does strange stuff. It will evaporate and deposit on your windows. You won't see anything spraying out the vents or anything dripping on the floor. Just takes a tiny leak.
I would think after 35 years any vinyl in your car would be all out of "fog".
cfield@ll.net
PostPosted: Wed Jul 25, 2001 2:24 pm
: Thanks for the info but i don't think those are
: the causes. My windows fog up slowly, over
: the course of a few days. And it happens
Do you smoke?
klesteb@aol.com
PostPosted: Wed Jul 25, 2001 8:10 pm
: Do you smoke?
No, I don't smoke. I'll check the heater core. Thanks for the info.
Orionsax7@cs.com
PostPosted: Thu Jul 26, 2001 12:30 pm
Alex, my '91 Stealth does the same thing----very strange isn't it??? Dodge might have a solution, have you ever asked them?
PostPosted: Thu Jul 26, 2001 1:09 pm
: first off, let me apologize for using this
: slant 6 site for this question.
: For anyone that might have similar
: experience.....the windows in my 65' valiant
: v100 keep getting fogged up. I'll clean them
: with window cleaner than they get fogged up
: again a few days later. Anyone know how to
: treat this?
I vote for a small leak in the heater core. This is the most common cause.
Chuck
webmaster@omnipages.com
