It is currently Thu Nov 26, 2026 10:48 pm
 Post subject: soft pedal
PostPosted: Thu Aug 30, 2007 7:11 am
while changing out the pads on my front discs, (75 with power brakes) i let the brake fluid drain out of the master. I bled the wheels but did not bleed the master cylinder. when the car is off i have a firm pedal. when the car is on the pedal goes to the floor with no resistance. do i just have to bench bleed the master and then re-bleed all four wheels, or is there something else going on? the discrepancy between car on and car off is more than my diagnostic mind can handle.
God took you away, then brought you back to me.
