It is currently Wed Jun 17, 2026 1:21 pm
 Post subject: Oil Pressure Sender?
PostPosted: Mon Sep 17, 2007 8:53 am
Car Model: 1968 Plymouth Valiant 100
While rewiring the engine compartment I had to replace a gray wire going to (what the service manual says) the oil pressure sender. I had to use a typical crimp-on terminal which had to be manipulated on. While replacing other parts during this project, should I replace this sender too? And if so, how do I remove it and the process in doing that. Thanks in advance -Dan
PostPosted: Mon Sep 17, 2007 9:49 am
The pressure senders can eventually rupture and leak oil. You can still buy new ones, and for the time being you can even still buy well-made new ones if you get a good brand (Standard-Bluestreak or Echlin). A special oil pressure sender/switch socket is used to remove and install.
PostPosted: Mon Sep 17, 2007 9:58 am
Is it something that I could do myself? How difficult is it and where can I buy this tool from? Also, is there any preparation such as draining the oil? I'm just trying to work my way through this car and replace what is needed, or should be replaced, as I go along. Thanks -Dan
PostPosted: Mon Sep 17, 2007 11:19 am
You needn't drain the oil. The socket can be had at any good auto parts store. And it's as simple as removing and installing a bolt.
PostPosted: Mon Sep 17, 2007 11:23 am
You the man Dan. Thanks again
PostPosted: Mon Sep 17, 2007 11:47 am
Sorry, another question. I just looked it up on napa and it has two parts. One is the oil pressure gauge switch and the other one is oild pressure light switch. Which one is this that I'm replacing? Here are the pics of both at napa.
oil pressure gauge switch p/n ECHOP6622
oil pressure light switch p/n ECHOP6451
PostPosted: Mon Sep 17, 2007 11:59 am
OP6451 is correct. The other one is for cars with an oil pressure gauge (rather than a red warning light).
PostPosted: Mon Sep 17, 2007 12:25 pm
Gotcha, thanks again!
PostPosted: Mon Sep 17, 2007 6:03 pm
Just be ginger about snugging it in, you can go too deep with the threading and bust out that part of oil pump, making replacing the oil pump the next job on the list...
