It is currently Wed Nov 18, 2026 7:19 am
PostPosted: Sun Sep 16, 2007 3:05 pm
Hey All,
I am trying to get the timing gear off the crank, and having quite a time with it. Stuck, stuck, stuck.
I got it to move about 1/4 inch and that is it! I had to put two cold chisels 180 degrees from eachother and tap them downward between the gear and the block. I moved the gear away from the block the width of the cold chisels, but now I am stuck.
Is there some secret to this? Sheesh I wish my FSM was here arlready as I am wondering if I am missing some special 1979 ONLY TIMING GEAR REMOVER CHRYSLER PART NUMBER blah, blah, blah............ :D
Thanks for any help guys.
C
-76 Cordoba, 360 4bbl
-68 Valiant, 273 2bbl
-67 Dart /6 4bbl, Leaning Tower of Power!!!
PostPosted: Sun Sep 16, 2007 3:16 pm
You need a gear puller. Commonly they have 3 legs that hook behind the gear and a central screw that presses against the crank. Sometimes a little heat helps.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sun Sep 16, 2007 5:01 pm
Figures :roll: I have two wheel pullers, but no gear puller. Guess I'll get one tomorrow.
I thought about putting a torch on it but figured I'd ask you guys first.
Thanks!
 Post subject: If it's tight...
PostPosted: Sun Sep 16, 2007 8:36 pm
You can put a torch on it if it's really tight, but the gear puller is the key...
PostPosted: Mon Sep 17, 2007 5:56 am
I got a loaner puller from Advance Auto last time I did this (free). They are about $50 for the Advance cheapy one, which worked fine, or about $200 for a name brand Snap On or similar.
PostPosted: Mon Sep 17, 2007 6:14 am
Yikes! A free loaner is sounding pretty good at those prices.
For the 2 times I would use this every 10 years, I am thinking $30 from harbor freight will suffice :D
PostPosted: Mon Sep 17, 2007 12:28 pm
Hey guys, the 4" puller at Advance auto was only $22 so I went ahead and got it.
I must have had the gear right on the cusp of coming off 'cause I turned the wrench one time and the gear popped off :)
anyhow thanks for putting up with all my noob stupidity :oops: :oops: :oops:
PostPosted: Mon Sep 17, 2007 1:43 pm
The one I have is a WalMart El-Cheapo that I've had for at least 30 years. It's virtually identical to this $12.99 unit from Harbor Freight.
http://www.harborfreight.com/cpi/ctaf/d ... mber=45977
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
Users browsing this forum: Amazon [Bot] and 4 guests
