It is currently Fri Nov 27, 2026 11:20 am
 Post subject: What transmission?
PostPosted: Sun Sep 16, 2007 10:46 pm
Sorry if this sounds like a dumb question, but what is the 63 Dart, slant 6 pushbutton tranny called? Is is a 904? Or something else? Thanks for the help.
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Sun Sep 16, 2007 11:59 pm
6 Pack Dart
I think it's called a 904 cable shifted, there is something about the drive line u-joint (the front one) that is different frome the later 904's
PostPosted: Mon Sep 17, 2007 12:00 am
Not so dumb if you don't know------
If the pan under the trans is almost square it's a 904,
if it has a leg out to under the dip stick it's a 727......
The early ones will have a ball and trunnion ujoint (detroit ball in chev lingo),
later models after 65 will have a slip yoke......
Models up to 65 will all be cable pushbutton shift, 65
will still be cable shift but moved to the column (or floor shift),
66 and later linkage shift.
odd's say you got a 904
http://imageevent.com/jeffc
62 D100 225 3sp lwb
64 D100 A318 727pb custom lwb
66 D100 A318 4sp lwb
68 D100 B383 727 swb
65 Belveder A318 727 4d
65 Dart GT LA273 2bbl 904
73 Scamp 225 2bbl 4spOD
Old iron or no iron
PostPosted: Mon Sep 17, 2007 7:43 am
The automatic trans in a '63 Dart is indeed a 904. It is informally called a cable-shift 904, or a dual-pump 904, and it has a flanged rather than splined output shaft.
It is not a 727.
PostPosted: Mon Sep 17, 2007 9:41 am
Thank you everyone. That's what I figured, but I wanted to be sure.
1970 Nova 12.53@108
1970 Bug 15.38@87
