It is currently Mon May 25, 2026 6:24 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 7 posts ]
PostPosted: Tue Jul 31, 2001 1:20 pm
He insists we install the engine with the manifold/intake off. To me this is plain stupid considering those little triangular washers are a pain to attach while the engine is in. Does the manifold/intake make it easier to tilt the engine to line it up to the tranny? I would think that the intake would be a good leverage point. He's affraid that the stuff will be in the way of the motor mounts even though its visibly evident that the installation will be easy as pie with everything bolted up!...
PostPosted: Tue Jul 31, 2001 2:24 pm
: He insists we install the engine with the
: manifold/intake off. To me this is plain
: stupid considering those little triangular
: washers are a pain to attach while the
: engine is in. Does the manifold/intake make
: it easier to tilt the engine to line it up
: to the tranny? I would think that the intake
: would be a good leverage point. He's affraid
: that the stuff will be in the way of the
: motor mounts even though its visibly evident
: that the installation will be easy as pie
: with everything bolted up!...
I have found it easiest in a narrow body valiant to have the manifolds on. I also like to leave the drivers side engine mount off the block until i get the motor in position. Its easier for me to bolt this mount on once i get everything in place.
wtzupdoc@pmcol.com
PostPosted: Tue Jul 31, 2001 2:48 pm
: I have found it easiest in a narrow body
: valiant to have the manifolds on. I also
: like to leave the drivers side engine mount
: off the block until i get the motor in
: position. Its easier for me to bolt this
: mount on once i get everything in place.
I always put them in with the manifolds on. Those triangle washers are a pain to get in the middle spots. I only leave the manifolds off if I am using headers.
aschumers@aol.com
PostPosted: Tue Jul 31, 2001 4:56 pm
I used to think like your dad and installed my engines without manifolds or the cylinder head. Last year, I installed the engine with head and manifold attached and found it to be much easier. And yes, leave the drivers side mount off until you have everything lined up- that helps too. I have R&R'ed a lot of engines in my 28 years of working on cars, and the slant six is the easiest.
pmvdlaan@picusnet.com
PostPosted: Tue Jul 31, 2001 9:51 pm
Your right the washers are a pain.......I've installed all mine with the manfolds ON!!!
Go ahead bolt it up!! <A HREF="http://bbs.annex.com/mrmopar">http://bbs.annex.com/mrmopar</A>
PostPosted: Tue Jul 31, 2001 11:27 pm
Your right, it is "easy as pie" to install the engine with the manifolds bolted on. (and almost everything else for that matter, including the tranny)
In fact, it's so easy, even a "child can do it", even with a big old Hyper-Pak intake hanging off the thing!
Close-up View, see how the strap is mounted?
PostPosted: Wed Aug 01, 2001 12:06 am
: I always put them in with the manifolds on.
: Those triangle washers are a pain to get in
: the middle spots. I only leave the manifolds
: off if I am using headers.
Thanks for reminding me Dennis,I knew there was some reason that I put them in with the intake off.
Will
slantsix@netzero.net
