Slant Six Forum https://slantsix.org/forum/ |
Somebody talk some sense into my dad! https://slantsix.org/forum/viewtopic.php?t=2496 |
Author: | Scott Woebcke [ Tue Jul 31, 2001 1:20 pm ] |
Post subject: | Somebody talk some sense into my dad! |
He insists we install the engine with the manifold/intake off. To me this is plain stupid considering those little triangular washers are a pain to attach while the engine is in. Does the manifold/intake make it easier to tilt the engine to line it up to the tranny? I would think that the intake would be a good leverage point. He's affraid that the stuff will be in the way of the motor mounts even though its visibly evident that the installation will be easy as pie with everything bolted up!... |
Author: | marty [ Tue Jul 31, 2001 2:24 pm ] |
Post subject: | Re: Somebody talk some sense into my dad! |
: He insists we install the engine with the : manifold/intake off. To me this is plain : stupid considering those little triangular : washers are a pain to attach while the : engine is in. Does the manifold/intake make : it easier to tilt the engine to line it up : to the tranny? I would think that the intake : would be a good leverage point. He's affraid : that the stuff will be in the way of the : motor mounts even though its visibly evident : that the installation will be easy as pie : with everything bolted up!... I have found it easiest in a narrow body valiant to have the manifolds on. I also like to leave the drivers side engine mount off the block until i get the motor in position. Its easier for me to bolt this mount on once i get everything in place. wtzupdoc@pmcol.com |
Author: | dschumers [ Tue Jul 31, 2001 2:48 pm ] |
: I have found it easiest in a narrow body : valiant to have the manifolds on. I also : like to leave the drivers side engine mount : off the block until i get the motor in : position. Its easier for me to bolt this : mount on once i get everything in place. I always put them in with the manifolds on. Those triangle washers are a pain to get in the middle spots. I only leave the manifolds off if I am using headers. aschumers@aol.com |
Author: | Pete Vanderlaan [ Tue Jul 31, 2001 4:56 pm ] |
: He insists we install the engine with the : manifold/intake off. To me this is plain : stupid considering those little triangular : washers are a pain to attach while the : engine is in. Does the manifold/intake make : it easier to tilt the engine to line it up : to the tranny? I would think that the intake : would be a good leverage point. He's affraid : that the stuff will be in the way of the : motor mounts even though its visibly evident : that the installation will be easy as pie : with everything bolted up!... I used to think like your dad and installed my engines without manifolds or the cylinder head. Last year, I installed the engine with head and manifold attached and found it to be much easier. And yes, leave the drivers side mount off until you have everything lined up- that helps too. I have R&R'ed a lot of engines in my 28 years of working on cars, and the slant six is the easiest. pmvdlaan@picusnet.com |
Author: | MrMopar [ Tue Jul 31, 2001 9:51 pm ] |
: He insists we install the engine with the : manifold/intake off. To me this is plain : stupid considering those little triangular : washers are a pain to attach while the : engine is in. Does the manifold/intake make : it easier to tilt the engine to line it up : to the tranny? I would think that the intake : would be a good leverage point. He's affraid : that the stuff will be in the way of the : motor mounts even though its visibly evident : that the installation will be easy as pie : with everything bolted up!... Your right the washers are a pain.......I've installed all mine with the manfolds ON!!! Go ahead bolt it up!! <A HREF="http://bbs.annex.com/mrmopar">http://bbs.annex.com/mrmopar</A> |
Author: | Doctor Dodge (Doug Dutra) [ Tue Jul 31, 2001 11:27 pm ] |
Post subject: | Re: Somebody talk some sense into my dad! *PIC* |
: He insists we install the engine with the : manifold/intake off. To me this is plain : stupid considering those little triangular : washers are a pain to attach while the : engine is in. Does the manifold/intake make : it easier to tilt the engine to line it up : to the tranny? I would think that the intake : would be a good leverage point. He's affraid : that the stuff will be in the way of the : motor mounts even though its visibly evident : that the installation will be easy as pie : with everything bolted up!... Your right, it is "easy as pie" to install the engine with the manifolds bolted on. (and almost everything else for that matter, including the tranny) In fact, it's so easy, even a "child can do it", even with a big old Hyper-Pak intake hanging off the thing! DD Close-up View, see how the strap is mounted? ![]() |
Author: | Will [ Wed Aug 01, 2001 12:06 am ] |
: I always put them in with the manifolds on. : Those triangle washers are a pain to get in : the middle spots. I only leave the manifolds : off if I am using headers. Thanks for reminding me Dennis,I knew there was some reason that I put them in with the intake off. Will slantsix@netzero.net |
Page 1 of 1 | All times are UTC-07:00 |
Powered by phpBB® Forum Software © phpBB Limited https://www.phpbb.com/ |
