It is currently Mon Nov 16, 2026 12:11 pm
 Post subject: EFI fuel tank
PostPosted: Thu Sep 20, 2007 10:07 am
Here I go again, thinking out loud...
If I were to cut out my spare tire well there would be a ton of room (well, 31"x34") for a fuel tank. Stay with me... Why not find a gas tank out of a EFI vehicle that would have the pump and everything built right in instead of using frame mounted pumps and surge tanks.
Any thoughts on wether or not I should spend a few days measuring tanks or is my idea flawed?
Chris'
Autobody
Restoration
Service
PostPosted: Thu Sep 20, 2007 12:49 pm
See if this link works for you. If not PM me and I'll hook you up.
http://sports.groups.yahoo.com/group/mo ... sage/25850
PostPosted: Fri Sep 21, 2007 6:57 pm
As long as you carried a temp spare, I don;t see anything wrong with the idea. Josh, I could not easily get the link to work for me. I have a Yahoo account, but I forgot my passward. It's been ages since I used it, and likely they have cut me off again anyway. What is the nature of the site you were sending cars to.
I figure I might eventually go the internal pump route with a modern tank some day. Tht would free up alot of space under the hood. I have been thinking a future project might be to get a modern tank and pump set up in the Dart..
Sam
PostPosted: Sat Sep 22, 2007 6:25 am
Why not buy a replacement tank for your car and rework it to take a modern in-tank pump and pick-up? Then you know it would fit and there would be no need to cut the trunk etc.
PostPosted: Sat Sep 22, 2007 7:35 pm
Any idea worked well is OK. The thing about modern tanks that is nice is they have the proper baffles, vents and return lines to work already. I can see the appeal of both, and would probably think long and hard about the advantages of both before I started such a project. But your idea, cavisco, certainly has merit.
Sam
