It is currently Mon Nov 16, 2026 8:56 am
 Post subject: rear cam bearing
PostPosted: Sun Sep 16, 2007 12:51 pm
charlie , did i hear you say that you once had a can bearing spin and you left it and drilled new passages, i have the block apart again and noticed the hole are miss aligned, i cant fish a wire through at all, the hole from head down looks easy but the one from main cap is on an angle will a drill chamfer the side of the bearing enough or do i have to replace it and pin it .help please,this is the second time.
PostPosted: Sun Sep 16, 2007 12:57 pm
See this thread.
 Post subject: cam bearing
PostPosted: Sun Sep 16, 2007 4:59 pm
i need some impute, just finished cleaning the engine and reinstalling crank/pistons/cam/timing gear,left the cam bearing were it was about 3/4in of it mark to line with oil hole .the top oil hole was easy just drill straight through then chamfer the new hole with a durr.the oil hole to the crank was trouble ,i drilled until i broke though the bearing surface then used a round burr the smooth the hole but the only thing is the hole is more a slot about 1/2in long were the drill bit went along the back of the bearing,do anybody see this causing any problems.oh i did blow air through with cam installed and turn it and air was passing through.thanks :?:
PostPosted: Sun Sep 16, 2007 7:22 pm
A longer oil feed hole is not a problem as long as there is a seal at the cam bearing to journal. (You don't want excess oil pressure loss)
I always grind the back-side of the cam bearings to get more oil flow down to the main and rod bearings.
 Post subject: cambearing
PostPosted: Mon Sep 17, 2007 3:46 pm
doug i didnt want to remove the bearing because it looks like it stoped in the same position that the stock bearing did when it spun.the hole to the head looks fine but the hole in the main oil feed passage looked like what you have done only it on the bearing face side,i don't think i will lose oil pressure pass the bearing but the flow might be increased to the valvetrain because of the how long the slot is,what do you think?
PostPosted: Mon Sep 17, 2007 5:17 pm
Don't worry about it, the oil will only flow thru the cross-hole when it is "uncovered" at both ends.
Seeing that only one of the two holes is now elongated, there should be no change in the amount of oil to the rocker arm shaft.
PostPosted: Mon Sep 17, 2007 5:34 pm
thanks, doug
PostPosted: Wed Sep 19, 2007 7:33 pm
now i know what a top fuel team goes through, had everything ready to go so i primed the engine no intake or excessory, oil pressure went to 40lbs but nothing coming from rockers,removed the engine striped it down again to find rear cam bearing moved again, this is a new set only put in 2 weeks ago, called and a new over size are 1 week away, so i pulled an old one from old block and installed it had to clean the burred up edges and i clean both surface a put 5min epoxy before the bearing went in then sanded surface untill cam spun freely,will it all back together fire it up and had oil to rockers ,i just hope this holds for this last weeking of racing,wish me luck i`ll need it.
PostPosted: Wed Sep 19, 2007 7:42 pm
Good luck eh!
PostPosted: Thu Sep 20, 2007 6:00 am
Good luck, Terry! Hard work and improvisation often wins the day...
PostPosted: Fri Sep 28, 2007 6:02 pm
old bearing held perfect, but i still hurt head gasket on #1 cyl,i removed the to 600`s and installed a 750 but forgot to pull the power valve and put in a plug and jet up after talking to charlie i hope that was my lean condition i will find out this next weekend.never new a blower would keep the power valve closed unless it is boost referenced, :oops:
 Post subject: Re: cambearing
PostPosted: Sat Sep 29, 2007 1:02 am
That is not necesasarilly so, but it could under certain conditions. The smaller the carb the more likely this could happen. Also at a less then full throttle acceleration.
PostPosted: Sat Sep 29, 2007 1:49 pm
will if nothing else it`s something i don`t have to think about, hopefully i have it rich enough so i have a chance to make more than one full pass so i can see some tuning results. :?:
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot], Google [Bot] and 5 guests
