It is currently Tue May 19, 2026 2:15 am
 Post subject: Rear end flutter noise?
PostPosted: Sat Sep 29, 2007 7:38 pm
I just swapped a 1975 BBP 7 1/4 into my 63 Val and now have a "fluttering" sound at speed. Is this likely an axle bearing or something deeper? The unit is a low mileage piece with zero leaks (2.76). I have installed a new u-joint in the driveline and the Ball & Trunion is tight and well lubed. Thanks for any input! - M
. . . there was good sport at his making.
PostPosted: Sat Sep 29, 2007 8:05 pm
Bearings usually make a rumbling/grinding noise. "Flutter at speed" often indicates a problem with the ring and/or pinion gear's tooth surfaces...usually rust pits/roughness on tooth surfaces. Rather common on low-miles units that have sat for years. The lube all drains off the stationary teeth and rust sets in. :-( Usually doesn't affect the actual serviceability of the rear axle, just makes an annoying noise. You may want to pull the cover and check the ring and pinion carefully.
 Post subject: Thanks!
PostPosted: Sun Sep 30, 2007 8:57 am
That's a better scenario than I had hoped! And Dan, thanks again for that hose clamp method of removing the parking brake cables. It worked flawlessly!
 Post subject: Re: Thanks!
PostPosted: Sun Sep 30, 2007 8:59 am
Que? Hose clamp?
PostPosted: Sun Sep 30, 2007 9:09 am
Hose clamp method for emergency brake cable removal: See here.
PostPosted: Sun Sep 30, 2007 10:45 am
Thanks Dan :o
