| Rear end flutter noise? https://slantsix.org/forum/viewtopic.php?t=25138 |
| Author: | Michael [ Sat Sep 29, 2007 7:38 pm ] |
| Post subject: | Rear end flutter noise? |
I just swapped a 1975 BBP 7 1/4 into my 63 Val and now have a "fluttering" sound at speed. Is this likely an axle bearing or something deeper? The unit is a low mileage piece with zero leaks (2.76). I have installed a new u-joint in the driveline and the Ball & Trunion is tight and well lubed. Thanks for any input! - M |
| Author: | SlantSixDan [ Sat Sep 29, 2007 8:05 pm ] |
Bearings usually make a rumbling/grinding noise. "Flutter at speed" often indicates a problem with the ring and/or pinion gear's tooth surfaces...usually rust pits/roughness on tooth surfaces. Rather common on low-miles units that have sat for years. The lube all drains off the stationary teeth and rust sets in. |
| Author: | Michael [ Sun Sep 30, 2007 8:57 am ] |
| Post subject: | Thanks! |
That's a better scenario than I had hoped! And Dan, thanks again for that hose clamp method of removing the parking brake cables. It worked flawlessly! |
| Author: | Rug_Trucker [ Sun Sep 30, 2007 8:59 am ] |
| Post subject: | Re: Thanks! |
Quote: That's a better scenario than I had hoped! And Dan, thanks again for that hose clamp method of removing the parking brake cables. It worked flawlessly!
Que? Hose clamp?
| Author: | SlantSixDan [ Sun Sep 30, 2007 9:09 am ] |
Hose clamp method for emergency brake cable removal: See here. |
| Author: | Rug_Trucker [ Sun Sep 30, 2007 10:45 am ] |
Thanks Dan |
