It is currently Sun Jun 07, 2026 2:45 pm
 Post subject: Carb Question
PostPosted: Sun Sep 30, 2007 7:03 pm
Will a 73 Duster Slant 6 two barrel carb and intake work in a 63 Dart with a factory throttle cable?
1963 Dodge Dart -225 Slant 6, 904, 2.76's, 18.84 @ 73
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Mon Oct 01, 2007 11:15 am
If your 63 Dart has been converted to a later "cable type" linkage, the 73 carb will work.
All 63 SL6 cars had a mechanical "rod type" accelator linkage from the factory.
PostPosted: Tue Oct 02, 2007 12:17 am
I still have the rod type. is there any way to adapt the rod type linkage to the 73 carb?
1970 Nova 12.53@108
1970 Bug 15.38@87
PostPosted: Tue Oct 02, 2007 8:17 am
Yep, you can follow Old6Rodder's method, photo essay here. Note this will require a different intake manifold configuration (modified 1bbl intake). If you want to use the factory 2bbl intake, you have to convert to cable throttle.
Just to save you some potential parts-chasing hassle later, your 2bbl setup may have been found on a '73, but it didn't originally come on a '73. The 2bbl wasn't available in North America on the slant-6 until '76.
PostPosted: Tue Oct 02, 2007 11:23 am
Dan
Thanks for the timely posting of the link to Old6's album. I had just PM'd him for it as I hadn't saved it.
David.......Here's a modified 1 bbl
Super Six Conversion Stromberg
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
