Carb Question
https://slantsix.org/forum/viewtopic.php?t=25153
Page 1 of 1
Author:  Davids63Dart [ Sun Sep 30, 2007 7:03 pm ]
Post subject:  Carb Question
Will a 73 Duster Slant 6 two barrel carb and intake work in a 63 Dart with a factory throttle cable?
Author:  Doc [ Mon Oct 01, 2007 11:15 am ]
If your 63 Dart has been converted to a later "cable type" linkage, the 73 carb will work.
All 63 SL6 cars had a mechanical "rod type" accelator linkage from the factory.
Author:  Davids63Dart [ Tue Oct 02, 2007 12:17 am ]
I still have the rod type. is there any way to adapt the rod type linkage to the 73 carb?
Author:  SlantSixDan [ Tue Oct 02, 2007 8:17 am ]
Yep, you can follow Old6Rodder's method, photo essay here. Note this will require a different intake manifold configuration (modified 1bbl intake). If you want to use the factory 2bbl intake, you have to convert to cable throttle.
Just to save you some potential parts-chasing hassle later, your 2bbl setup may have been found on a '73, but it didn't originally come on a '73. The 2bbl wasn't available in North America on the slant-6 until '76.
Author:  61 V200 [ Tue Oct 02, 2007 11:23 am ]
Dan
Thanks for the timely posting of the link to Old6's album. I had just PM'd him for it as I hadn't saved it.
David.......Here's a modified 1 bbl
