It is currently Thu Nov 19, 2026 7:52 pm
PostPosted: Sun Oct 07, 2007 1:03 am
Car Model: 1972 Dodge Dart Swinger
Hey you guys,
Lately I have been seeing black spots on the ground after I start my car and the inside of my tailpipe is all sooty and black. I'm getting tired of cleaning my driveway every other day. Does anyone no what this is? I think running way too rich. If so, what is the best way to tune the holley 1920? I have a tach, vacuum gauge, and most likely what ever else is needed to tune a car with the exception of an exhaust gas analyzer ( $$$).
Thanks for your help!
-Angelo
1972 Dart Swinger, 225cid
PostPosted: Sun Oct 07, 2007 4:02 am
I only does it in the morning, when she runs for a few minuets on
choke... Right?
PostPosted: Sun Oct 07, 2007 4:09 am
Mine does that as well. I park on blacktop, so it's not as much of a worry for me. I figured it was just in the morning when the choke is on and the engine is running rich. I've never had that problem later in the day.
PostPosted: Sun Oct 07, 2007 5:41 am
This suggests the choke thermostat and/or choke pull-off need to be adjusted. What year and model is the car?
PostPosted: Sun Oct 07, 2007 3:06 pm
Its a 72 swinger with the 225 and 1920 carb.
PostPosted: Sun Oct 07, 2007 3:35 pm
I have the same set up. I just put more bend in the choke rod to make it shorter so it doesn't stay on so long. When you get that much black soot it is over choked. I bent the rod so it is like a "S" or "Z" almost 90 degree bends. After a few times adjusting it, I got just right. It has been running fine for about a year now, no more black soot. It is a simple fix.
PostPosted: Sun Oct 07, 2007 3:56 pm
Bending rods not meant to be bent — such as the choke thermostat pushrod — is a brute-force/hamfist approach. The choke thermostat is adjustable via the locknut on the side - you have to remove the thermostat from the manifold in order to adjust it. The choke pull-off is adjusted by altering the width of the legs of the "U" bend in the pull-off link. But before we adjust anything, have you got the correct thick carb base gasket installed?
PostPosted: Sun Oct 07, 2007 4:08 pm
I LOVE hamfist and sweet potatoes!
PostPosted: Sun Oct 07, 2007 7:46 pm
Im pretty sure its the thick one.
Im pretty sure its the thick one. How thick should it be?
PostPosted: Sun Oct 07, 2007 8:01 pm
About 5/16" thick.
Unless yours is a super low-miles unit, you may find it difficult to get a good adjustment on your choke. I don't spend much time messing with these any more...I just toss the old type unit and put on one of the Electric choke kits.
Users browsing this forum: DuckDuckGo [Bot], Google [Bot] and 2 guests
