It is currently Fri Nov 20, 2026 2:54 am
PostPosted: Mon Oct 08, 2007 3:42 pm
Car Model: 62 Lancer GT
Can anyone tell me how many traiangle wahers 1 manifold set up uses. I have a container full I am going to seperate and put for sale what I don't need thanks........
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
PostPosted: Mon Oct 08, 2007 4:14 pm
10 trangle washers per engine, 1 conical washer (center) and 2 brass washers with special nuts (ends)
Early engine FSM shows 8, with 2 additional conical washers used on the two lower-center studs. (3 total)
http://www.slantsix.org/articles/manifo ... unting.htm
PostPosted: Mon Oct 08, 2007 4:34 pm
Thanks Doc...
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Tue Oct 09, 2007 6:13 pm
My two 65 darts came with three conical washers mounted on the center studs(1 on top, 2 on bottom). Consequently only 8 triangular washers were used.
Users browsing this forum: Bing [Bot] and 5 guests
