| How many triangle washers for 1 manifold set up? https://slantsix.org/forum/viewtopic.php?t=25271 |
| Author: | JohnnyDees [ Mon Oct 08, 2007 3:42 pm ] |
| Post subject: | How many triangle washers for 1 manifold set up? |
Can anyone tell me how many traiangle wahers 1 manifold set up uses. I have a container full I am going to seperate and put for sale what I don't need thanks........ |
| Author: | Doc [ Mon Oct 08, 2007 4:14 pm ] |
10 trangle washers per engine, 1 conical washer (center) and 2 brass washers with special nuts (ends) Early engine FSM shows 8, with 2 additional conical washers used on the two lower-center studs. (3 total) DD http://www.slantsix.org/articles/manifo ... unting.htm |
| Author: | JohnnyDees [ Mon Oct 08, 2007 4:34 pm ] |
Thanks Doc... |
| Author: | DonPal [ Tue Oct 09, 2007 6:13 pm ] |
My two 65 darts came with three conical washers mounted on the center studs(1 on top, 2 on bottom). Consequently only 8 triangular washers were used. |
