It is currently Wed May 27, 2026 2:49 pm
PostPosted: Wed Oct 17, 2007 6:47 am
i am going to be getting a slant out of a 64 power wagon soon with the plans to build a long rod motor with MegaSquirt efi. i haven't decided on compression yet.
are there any differences that would make this engine a poor choice? i will be putting a four speed behind it and possibly a five speed soon. the only problem i can see running into would be the fly wheel end of the crank.
zedpapa
1970 dodge dart w/225 /6 bored .040" over, holley 390cfm w/vac. sec., compcams 252s, clifford shorty headers w/2.5" exhaust w/flowmaster, f-body 11" front discs, aluminum A-833OD, 8 1/4 w/3.21 SG
soon to have 5 gears!!!
PostPosted: Wed Oct 17, 2007 7:23 am
There is nothing different between your truck engine and a car engine that would prevent you from using it, but there was an improvement in the head, 1967 and later heads have better combustion chambers, also there are some improvements in the block 68-75 blocks are slightly better, extra ribbing.
1966 Signet
Turbo Slant Six
PostPosted: Wed Oct 17, 2007 11:44 am
Car Model: 1967 Dodge Dart 270
The 64 Power Wagon motor should have a (shot peened) crank, for heavy duty application. The passenger car motors had the standard forged crank.
PostPosted: Wed Oct 17, 2007 10:28 pm
the head thats on the motor is a peanut head, but i have a 68 or 69 head that i am porting and getting big valves for.
the fly wheel should bolt on no problem, right? is the pilot bearing the same size? besides the crank being shot peened(which is better, right?) all the dminsions are the same? sorry for all the questions, just make sure i can use what i'm getting.
zedpapa
PostPosted: Thu Oct 18, 2007 12:41 am
Get the numbers off the engine to be sure of what you're actually getting.
http://www.slantsix.org/articles/parts-matrix/jpg.htm
http://www.slantsix.org/articles/dutra- ... blocks.htm
http://www.slantsix.org/articles/combus ... hamber.htm
