It is currently Fri Oct 09, 2026 4:39 pm
 Post subject: A Few Newbie Questions
PostPosted: Tue Oct 09, 2007 8:11 pm
It's been awhile since I thought about my old slant six, My Dodge van think it was a 75 . Killed that van way back on my High schoool graduation night by taking out a telephone pole.
Anyway to the present. A have a 92 Mighty Max pick up, basiclly a Dodge Ram 50, with a soon to be wore out 4 banger. I've thought of some differnt motor ideas and am intriqued with a slant 6 in the engine compartment and I like differnt. How much room from firewall to radiator would be needed to fit a slant 6 in there.
PostPosted: Tue Oct 09, 2007 8:35 pm
The SL6 is 32 inches long, water pump 'nose' to bellhousing flange.
Figure 34 to 35 inches of engine bay, plus any fan thickness and the radiator.
PostPosted: Tue Oct 09, 2007 8:54 pm
Small blocks will fit a D50 if you put the radiator in front of the core support. The slant is longer.
PostPosted: Tue Oct 09, 2007 10:09 pm
Just a heads up, my first car when I was 16 was 91 mighty max, the engine was awesome, we got the tranny (A-500) rebuilt 2 times and 3 torque converters. It was a headache... so shove a slant in! Also if it is an automatic I'm pretty sure the A-904 is a replacement without the o/d
PostPosted: Wed Oct 10, 2007 8:09 pm
I did some measuring tonight and it looks like a slant6 is not going to fit without firewall or other major front end mods :cry:
Guess I'll have to try and go the V6 or V8 route.
I'm addicted to brake fluid...But don't worry I can stop anytime!!
PostPosted: Thu Oct 11, 2007 7:53 am
The other option would be to put in a Mitsubishi 4G63 Turbo four banger - the same motor used in turbo Eclipses and the Lancer Evolution. It's very closely related to the stock D50 / Mighty Max motor, and can make a huge amount of power.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Thu Oct 11, 2007 10:10 am
Hadn't even thought of something like that. I asume enough guys crash them that a motor with all the computer stuff would be "Fairly" easy to find?
PostPosted: Thu Oct 11, 2007 10:32 am
Yeah, the problem with a 4G63 is that the front drive blocks don't bolt to the rear drive transmissions.
PostPosted: Thu Oct 11, 2007 10:45 am
I've seen it done before, as long as the truck has a 4G6x motor of some sort. The usual issue seems to be that the manifold needs to be modified because the stock throttle body would hit the firewall.
PostPosted: Thu Oct 11, 2007 11:59 am
It's been done, but the top bellhousing bolt holes are farther apart on a rear drive block.
PostPosted: Sun Oct 14, 2007 6:52 am
I guess since this thread is already off the original slant6 idea I'll ask another Mitsubishi question. I had a 95 New Yorker with a 3.5L V6 which I'm sure was a Mitsubishi motor although it was FWD. Did this engine get used in any RWD vehicles?
Users browsing this forum: DuckDuckGo [Bot] and 28 guests
