It is currently Mon Jun 01, 2026 9:03 pm
 Post subject: Squeaky break
PostPosted: Mon Oct 15, 2007 12:31 pm
Hi
The passenger side rear break on my 1965 Valiant won’t stop squeaking. I took it to a break shop and they did nothing to make it better. I took it back and they pulled the old blame the customer routine.
I have installed new break lines and replaced the master cylinder (as well as shoes etc) but the break still keeps dragging.
Do you think it might be a weak spring or perhaps the wheel cylinder has to be replaced?
PostPosted: Mon Oct 15, 2007 1:47 pm
If you haven't changed the springs yet, do so now. While it's probably not what is causing them problem, but if you don't know how old they are, they are probably getting old enough to run the risk of breaking.
Is this a constant squeal, or does it only occur when you apply the brakes? Also, what type of material are your shoes made from?
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Mon Oct 15, 2007 3:36 pm
I am not sure about the type of material that the shoes are made of but they are just standard brakes. I will certainly look into the different springs though.
PostPosted: Mon Oct 15, 2007 3:37 pm
Oh yes, it is constant squeak and only stops when you apply the brakes.
PostPosted: Wed Oct 17, 2007 10:37 am
I've had some odd noises that were cured by just removing the wheel cover; applying the brakes dampens the vibration and stops the noise. A little rust scraping between the backing plate and drum can also setup a vibration
Sometimes, a bad shock can cause a lot of noise too by converting minor motion into vibration. If you jack back end up (securely support it on jack stands) & run it that way, does the squeek appear?. If not, it might be something else setting up the vibration; if it does, you can remove the wheel, try it, then remove drum and try.
PostPosted: Wed Oct 17, 2007 12:48 pm
Hi
I have changed the shocks both front and rear. I did not really describe the squeak that well.
It is a chirping sound that constantly occurs while driving. When the breaks are applied the chirping stops. Thus, it just seems like something is continually catching or rubbing.
I think this weekend I will have a chance to pull of the drum.
I thin that a change of springs might help things but I have a leak somewhere in the brake system so that is why I suspect the brake cylinder.
Any more suggestions are definitely welcome.
PostPosted: Wed Oct 17, 2007 5:21 pm
The pads are in constant contact with the rotor surface. If the rotor is slightly out of true it could cause the pad to work back and forth in the caliper which might cause a cyclical chirp such as you describe. Does the interval between chirps change as you speed up or slow down?
*edit* I assumed disk brakes but on reading again I think that was a faulty assumption. Still, the noise you're describing could be caused by an out of round brake drum, or maybe a bent backing plate. Take the drum off and lubricate the pads on the backing plate where the shoes rest against it. Inspect the drum for signs of rubbing on the inside of the wheel mounting surface.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Oct 18, 2007 9:20 am
It's a long shot, but while you've got the car up I'd suggest you check that the universals aren't binding up or damaged. The only way I've found to do that well is to unbold the driveshaft at the axle and turn them by hand with the trans in neutral.
PostPosted: Thu Oct 18, 2007 12:32 pm
Hi
I think that the chirp corresponds directly to the velocity of the vehicle.
When I speed up, the rate of the chirp seems to as well.
If it is out of true then should I take it to a place that machines brake drums?
I guess that I may have to replace it.
PostPosted: Thu Oct 18, 2007 5:12 pm
Machining the drums ( you should do both while you're at it ) may be necessary but I would check everything else too, just to be sure there isn't something bent or misaligned.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Fri Oct 19, 2007 10:00 am
dakight's posting reminded me of odd problem I had long ago with an AMC; it's a long shot, but maybe it's relevant.
The 1973 AMC Hornet's drums would go significantly out of round with use, but would return to round after they were removed from the car awhile - I ended up w/ 2 sets that did that that I'd alternate between them <1/2 year or so. I never understood why they'd do that, but it was very reproducable.
If your drums distort on the car, but return to normal off the car, it could maybe cause something to rub somewhere.
PostPosted: Tue Oct 23, 2007 6:45 am
Thanks for the advice.
I took a hammer and tapped things to remove any sort of rust that might be causing things not to move freely. This seemed to realign things as well and the squeaking has stopped.
PostPosted: Tue Oct 23, 2007 6:38 pm
Yup, sometimes all you need is a bigger hammer.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
