It is currently Fri May 29, 2026 10:02 pm
PostPosted: Thu Oct 18, 2007 7:14 pm
So I'm swapping the shaft out of a manual steering column into my original power column.
Also what is the correct name for the coupler/joint/wobbly thing at the bottom end? -And, is it something that I should replace while it's out?
PostPosted: Fri Oct 19, 2007 6:26 am
Steering Coupler or Coupling.
I'd rebuild it. Kits are available.
