| Steering Conversion Details https://slantsix.org/forum/viewtopic.php?t=25436 |
| Author: | sethmcneil [ Thu Oct 18, 2007 7:14 pm ] |
| Post subject: | Steering Conversion Details |
So I'm swapping the shaft out of a manual steering column into my original power column. Also what is the correct name for the coupler/joint/wobbly thing at the bottom end? -And, is it something that I should replace while it's out? |
| Author: | slantvaliant [ Fri Oct 19, 2007 6:26 am ] |
| Post subject: | Re: Steering Conversion Details |
Quote: Also what is the correct name for the coupler/joint/wobbly thing at the bottom end?
Steering Coupler or Coupling.Quote: -And, is it something that I should replace while it's out?
I'd rebuild it. Kits are available.
