Three on tree to three on floor?
https://slantsix.org/forum/viewtopic.php?t=25510
Author:  slantfin [ Wed Oct 24, 2007 4:40 pm ]
Post subject:  Three on tree to three on floor?
I replaced the stock three speed manual in my 67 a-body with an untried four speed, "It oughta just bolt in". Trans came with oldish Hurst shifter. Problem is sometimes I have second gear, upshift or downshift, and sometimes won't go into second. Everything else works ok. Does anyone with experience in this area have a feeling of whether this transmission is junk? It seems strange that it sometimes goes into gear and sometimes not. :?
Author:  Romeo Furio [ Thu Oct 25, 2007 4:03 pm ]
Post subject:  shifter
Check your shifter rods for stripped threads. My friends son was having the same problem with his Cuda and would not hold adjustment. Just a thought..........
Author:  slantfin [ Fri Oct 26, 2007 2:15 pm ]
Post subject:  On the right track
I think you're right to think shifter, Romeo Furio. I took the car out today, and found I can always get it into second if I shift into fourth and then over into second. Shifter is old, but threads on adjusters are not the problem, since I had to torch them to get the cams to adjust out to the right position, so that everything is in neutral when a pin is in all the line-up holes.
Author:  newpoppop [ Sun Oct 28, 2007 6:08 am ]
sounds like synchronizers are bad...
Author:  slantfin [ Sun Oct 28, 2007 8:46 am ]
Post subject:  and that ain't good
That's what I'm afraid of.
Author:  slantfin [ Sun Oct 28, 2007 4:38 pm ]
Post subject:  Back out
OK transmission has been pulled. Now should I monkey around with this myself or is this a job best left to a "qualified repair shop" as the repair manual suggests. How much should I expect to pay for a rebuild? Or is a junkyard replacement the way to go? Opinions welcome.
