It is currently Thu Jun 04, 2026 2:20 am
 Post subject: valve stem seal size
PostPosted: Fri Dec 28, 2007 10:57 pm
I'm rebuilding a 225 slant in a '73 Valiant. The valve stem seals that came with the gasket kit have two different sizes. Six small ones and six higher seals. Because the old seals were almost disappeared i do not know what seal should go on what valve.
I think that the high ones should go on the exhaust. Is that correct?
Roelof
PostPosted: Sat Dec 29, 2007 1:05 am
The small seal goes on the exhaust valve stem, the large on the intake.
PostPosted: Sat Dec 29, 2007 9:36 pm
Thank you,
Roelof
