It is currently Sat May 16, 2026 6:00 am
 Post subject: Spark Plug Tubes...
PostPosted: Sat Oct 27, 2007 3:53 pm
Had a BLAST changing the o-rings. What a fun & quick little project. Whats up Slanters?
 Post subject: Re: Spark Plug Tubes...
PostPosted: Sat Oct 27, 2007 4:13 pm
Whats up Slanters?
The price of gas, ....... again. :shock: :?
PostPosted: Sat Oct 27, 2007 5:20 pm
Trying to find time and money to actually do something to my slants, except getting more cores... :?
Same old story............
PostPosted: Tue Oct 30, 2007 5:21 pm
What holds the tubes in? just the spark plugs?
68 Valiant Signet, 225, auto.
PostPosted: Tue Oct 30, 2007 6:11 pm
I always change spark plugs when I change my tube o-rings...
Or is it the other way around. :wink:
PostPosted: Tue Oct 30, 2007 6:13 pm
Yup, just the spark plugs.
PostPosted: Wed Oct 31, 2007 3:59 pm
This is something new to me.
I love this site.
How do you get the tubes out after you remove the plugs?
Superman
1981 D150
"The Khaki Machine"
PostPosted: Wed Oct 31, 2007 4:11 pm
The spark plug tubes are only present on cylinder heads made through 1974. '75 and up heads don't have them. But if you're working with a '74 or earlier head, sometimes the tube will be "glued" in place by the cooked O-ring. In that case, usually sticking a finger into the tube and exerting sideways pressure at the inner end will break it loose so it can be withdrawn.
PostPosted: Wed Oct 31, 2007 4:20 pm
Mine were extremely easy to extract. I simply removed the spark plug and stuck two fingers in the tube, gave it a wiggle and it pulled right out. I had one sticky one, behind the alternator. I just used duct tape (adhesive side out) on my finger for extra grip. Worked like a charm.
Users browsing this forum: Bing [Bot], Google [Bot], Rick Covalt and 16 guests
