It is currently Thu Nov 26, 2026 6:38 am
PostPosted: Fri Nov 02, 2007 7:10 pm
Get this noise when accelerating or coasting.New U-joints. Is this an out of balance shaft? New clutch kit also and gear oil in the 81/4.
A wrongly installed U-joint?
Or something else? What should I try first?
Surely someone has had a similar problem? THANKS!!
PostPosted: Fri Nov 02, 2007 8:24 pm
The smallest bit of u-joint off-set will make for a big vibration, chack that first.
A out of balance clutch will vibrate with engine RPM and not with vehicle speed.
Users browsing this forum: Google [Bot] and 12 guests
