| LOUD Vibration at 40-50 mph. https://slantsix.org/forum/viewtopic.php?t=25649 |
| Author: | thomasj6604 [ Fri Nov 02, 2007 7:10 pm ] |
| Post subject: | LOUD Vibration at 40-50 mph. |
Get this noise when accelerating or coasting.New U-joints. Is this an out of balance shaft? New clutch kit also and gear oil in the 81/4. A wrongly installed U-joint? Or something else? What should I try first? Surely someone has had a similar problem? THANKS!! |
| Author: | Doctor Dodge [ Fri Nov 02, 2007 8:24 pm ] |
The smallest bit of u-joint off-set will make for a big vibration, chack that first. A out of balance clutch will vibrate with engine RPM and not with vehicle speed. DD |
