It is currently Sun May 17, 2026 10:22 am
 Post subject: need rear end knowledge
PostPosted: Fri Nov 23, 2007 7:29 pm
Got a 63 dart what is the original rear end and what other rear ends will bolt up??? I know an early A-model 8 3/4 will but was is the original and what else??? thanks GRT
PostPosted: Sat Nov 24, 2007 4:35 am
The original rear end was the 7 1/4. As you noted the 8 3/4 will bolt up and the 8 1/4 from later A-dody models will also work. In both cases driveshaft modification will be needed so neither is truly a bolt and go swap.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Nov 24, 2007 5:16 am
knew about the drive shaft mod but was questioning the spring stands and width, thanks for the info....another question, the later A-body 8 1/4, small or big bolt pattern? thanks GRT
 Post subject: Lbp
PostPosted: Sat Nov 24, 2007 7:45 am
Since these were common in 1973-1976 A-bodies for HD/ Performance use, they got coupled with Disc Brakes so they are only LBP...
If stuck with SBP and a stockish rear, you're stuck with the 7.25" or 8.75" rear...
good luck,
PostPosted: Sat Nov 24, 2007 12:17 pm
my desire is to go to a large bolt pattern without much fanfair...so it looks like a rear end from a a 67 and up A body with 8 1/4 correct?
PostPosted: Sat Nov 24, 2007 12:47 pm
Large bolt pattern rears also came as 7 1/4 rear axles. Thes are cheaper and won't require a driveshaft modification. Look for 1973-up disc brake cars, or power durm brakes. MOST, not all a-bodies after 73 got large bolt pattern, but also SOME all drum brake cars after 73 got the small bolt pattern brakes. The post-73 small bolt pattern is rare, but documented.
The easiest swap is to find a 73-up 7 1/4 rear axle. It will bolt right in and probably have the large bolt pattenr, but always measure before you buy.
The downside (performance wise) is that it will most likely be geared for economy, not performance, ubt with gas prices the way they are i would say this is a good thing.
