It is currently Mon Nov 30, 2026 10:09 am
PostPosted: Tue Nov 20, 2007 8:34 pm
so ive accepted that fact that im gonna have to give up my smaller pattern mags when im doin my disc swap on my 72 valiant.
but... the 73 dart wit 318 doner car has the larger size in the rear, which i assume is a 7-1/4 too. so if i dont wanna carry two spares i gotta swap axles right? theres not smaller bolt pattern hubs?
PostPosted: Wed Nov 21, 2007 4:45 am
you can always have the rotors & axles re-drilled for the smaller bolt pattern-- if you so desire,
Lawrence
PostPosted: Wed Nov 21, 2007 5:42 am
It is not possible to just swap axles, in the 7 1/4 small bolt pattern rear, to get large bolt pattern. You must swap the complete rear end housing.
PostPosted: Wed Nov 21, 2007 12:37 pm
its possible to get the rotors re drilled? all i need is the front to be legit.
i havnt takin anything apart yet, but what do the studs press into, the hub, and then thru the rotors, or what? just seeing what it would take to do this
PostPosted: Wed Nov 21, 2007 1:03 pm
Not a good idea from a safety perspective.
PostPosted: Wed Nov 21, 2007 4:54 pm
will a redrill really drop the integrity of the rotor
PostPosted: Wed Nov 21, 2007 8:51 pm
You cannot redrill the large pattern rotors to the 5 on 4" pattern. Aside from the stud circle, the center would have to be turned down smaller than possible. Even if this would work, it would not be easier, cheaper or quicker to do.
If you have the donor car, you could just use the whole large pattern setup, including the wheels. They are usually 14" wheels, so your present tires could be swapped on.
