It is currently Sun Nov 15, 2026 4:09 pm
 Post subject: A body door hinges
PostPosted: Tue Nov 27, 2007 11:17 pm
Any one know if the front hinges on a four door dart will fit a 2 door dart same year?
PostPosted: Wed Nov 28, 2007 12:14 am
Acording to the info I have, yes. This goes for the front door hinges only, the rear hinges won't work to replace 2 dr hinges. Also, the hinges changed durring the 73 model year, both cars would have to be either before or after 7-1-73. The source I'm using is the Chrysler Muscle Car Parts Interchange Manual by Herd, it's not the final authority, I have found mistakes in this book. A body front door hinges seem to be the same from 67 to 7-1-73. I'm not sure, but I think they might have beefed up the hinge the same time they had to add the side impact bar inside the door in 73.
There are 3 things that will live forever, cockroaches, Keith Richards, and Slant Six Dusters !!!
http://s4.photobucket.com/albums/y128/slantasaurus/
take a look around
PostPosted: Wed Nov 28, 2007 10:47 am
It should work fine. I've never done this with the A-body's but I have taken hinges off of 4dr Satillites to use on Roadrunners.
Chris'
Autobody
Restoration
Service
PostPosted: Wed Nov 28, 2007 11:08 am
What is wrong with the original hinges? Unless they were damn near crushed by something they can be rebuilt.
Chris'
Autobody
Restoration
Service
PostPosted: Wed Nov 28, 2007 11:11 am
They'll fit fine. (...but only if you drill a buncha holes in 'em first! :mrgreen: )
PostPosted: Wed Nov 28, 2007 4:43 pm
The upper hinge on the drivers side , the holes are so elongated that the door drops 1/2 inch when opened.
My body man said they were beyond repair. Someone on this board offered me 4 door hinges, so I needed to know if they would fit.
Thanks for your input all.
