| Is anyone here running https://slantsix.org/forum/viewtopic.php?t=26034 |
| Author: | 65 dartman [ Wed Nov 28, 2007 5:55 pm ] |
| Post subject: | Is anyone here running |
a triple Weber or Dell'orto set-up on their slant. If so what series of carbs are you using? |
| Author: | 68barracuda [ Wed Nov 28, 2007 11:13 pm ] |
Contact http://www.pentastarparts.com.au/ pop them a mail They even stock the manifolds http://www.pentastarparts.com.au/sunsho ... _list&c=53 If it wasn't for the price of the carbs.. BTW the price is in Australian dollars |
| Author: | 65 dartman [ Thu Nov 29, 2007 3:17 am ] |
Thanks for the link. Yea, price of that set-up . . . .Oh well. |
| Author: | Slanted Opinion [ Thu Nov 29, 2007 6:24 am ] |
Don't forget that the price that you see is in Australian dollars... $250 Aussie is about $220 US at the moment. There is also the manifold setup (on the same website) for triple SU carbs. SU carbs are less expensive, I believe. Mentioning SU carbs is sure to ignite a small firestorm of debate as to their worth (or worthlessness); but I understand they can be a hot setup if done right. The design is ancient, going back to the early 20th century. Of course, there is the endless battle to keep any multiple carb setup "in-sync". The manifold is also a non-heated design, although I would think that fuel dropout would not be much of a problem with the short runner design. -Mac |
