It is currently Sat Jun 20, 2026 2:34 am
 Post subject: Is anyone here running
PostPosted: Wed Nov 28, 2007 5:55 pm
a triple Weber or Dell'orto set-up on their slant. If so what series of carbs are you using?
PostPosted: Wed Nov 28, 2007 11:13 pm
Contact
http://www.pentastarparts.com.au/
pop them a mail
They even stock the manifolds
http://www.pentastarparts.com.au/sunsho ... _list&c=53
If it wasn't for the price of the carbs..
BTW the price is in Australian dollars
Regards,
Fanie Gerber
http://www.valiant50.co.za
Just say I own a few Mopars
PostPosted: Thu Nov 29, 2007 3:17 am
Thanks for the link. Yea, price of that set-up . . . .Oh well.
PostPosted: Thu Nov 29, 2007 6:24 am
Don't forget that the price that you see is in Australian dollars... $250 Aussie is about $220 US at the moment.
There is also the manifold setup (on the same website) for triple SU carbs. SU carbs are less expensive, I believe.
Mentioning SU carbs is sure to ignite a small firestorm of debate as to their worth (or worthlessness); but I understand they can be a hot setup if done right. The design is ancient, going back to the early 20th century.
Of course, there is the endless battle to keep any multiple carb setup "in-sync". The manifold is also a non-heated design, although I would think that fuel dropout would not be much of a problem with the short runner design.
-Mac
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 1 guest
