It is currently Sun May 17, 2026 7:18 am
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 4 posts ]
 Post subject: new owner questions
PostPosted: Mon Aug 27, 2001 7:20 am
Hi , I just Inherited a 79 Custom with a slant six. I am trying to find out a little basic info onthis motor. We pulled the intake/exhaust off of it Saturday and found the exhaust was broke in to two pieces. I saw that some use a mopar header combo, some use a clifford combo. We want ours to be just a good daily driver right now. I would just like to know what is the best way to go.Stock intake/ exhaust or aftermarket
arabmem@hiwaay.net
 Post subject: Re: new owner questions
PostPosted: Mon Aug 27, 2001 7:51 am
: We pulled the intake/exhaust off of it Saturday and found the exhaust was broke in to two pieces. I saw that some use a mopar header combo, some use a clifford combo. We want ours to be just a good daily driver right now. I would just like to know what is the best way to go.Stock intake/ exhaust or aftermarket.
Hmmm. Being that it's a '79, I'm guessing it's a two-barrel intake/carb. If it's not, you're going to have to split the intake/exhaust anyway, I'd recommend looking for a two-barrel setup in the salvage yards while trying to find the exhaust. This conversion would give you better performance while still being a decent daily driver.
If you swap to a two-barrel, you'll need intake, carb, air cleaner, and especially throttle/kickdown brkts & linkages.
Your other options are; Headers...can be pricey if buying new.
Dutra Duals....possible option, can be pricey,depending on where your stock exhaust is broke. This would consist of (maybe) modifying your broken exh. casting, and purchasing one new casting from Doug Dutra. This setup gives you actually two exhaust manifolds, one on the front three, and one on the back three. It will add a bit more horsepower, but also requires an additional pipe running out back.
Slants have a penchant for breaking that long exhaust manifold, so it could be a toss-up by just replacing your stock setup back to original. BTW, you might want to take a close look at those studs...the ones holding the manifolds to the head.
Roger
GTS225@aol.com
PostPosted: Mon Aug 27, 2001 8:50 am
: Dutra Duals....possible option, can be
: pricey,depending on where your stock exhaust
: is broke. This would consist of (maybe)
: modifying your broken exh. casting, and
: purchasing one new casting from Doug Dutra.
: This setup gives you actually two exhaust
: manifolds, one on the front three, and one
: on the back three. It will add a bit more
: horsepower, but also requires an additional
: pipe running out back...
I have some info. on the Dutra Duals posted at:
<A HREF="http://www.dutra.org/doug/dougs-home-page.htm">http://www.dutra.org/doug/dougs-home-page.htm</A>
Link to Dutra Duals Info
PostPosted: Mon Aug 27, 2001 10:40 am
: Yeah the studs have to be replaced, two broke and the others are worn.On the subject of two barrels, you will have to bear with me it says it is a carter on the side, but no number. Junkyard today says that they have what I need for about 75 bucks is that a fair price? Where are the ID numbers located exactly also/ I looked on the block by the valve cover, but it does not have any letters just a series of numbers. Sorry for the long post but I'm just tryins to get her back on the road - thanks mike
: Hmmm. Being that it's a '79, I'm guessing it's
: a two-barrel intake/carb. If it's not,
: you're going to have to split the
: intake/exhaust anyway, I'd recommend looking
: for a two-barrel setup in the salvage yards
: while trying to find the exhaust. This
: conversion would give you better performance
: while still being a decent daily driver.
: If you swap to a two-barrel, you'll need
: intake, carb, air cleaner, and especially
: throttle/kickdown brkts & linkages.
: Your other options are; Headers...can be pricey
: if buying new.
: Slants have a penchant for breaking that long
: exhaust manifold, so it could be a toss-up
: by just replacing your stock setup back to
: original. BTW, you might want to take a
: close look at those studs...the ones holding
: the manifolds to the head.
: Roger
arabmem@hiwaay.net
