| 7 1/4 rearend https://slantsix.org/forum/viewtopic.php?t=2620 |
| Author: | Doobiemon [ Wed Aug 29, 2001 9:50 pm ] |
| Post subject: | 7 1/4 rearend |
My 7 1/4 rear end is slap wore out. My question, is this rear end worth rebuilding? Thought I got lucky at the boneyard the other day. Found a 76 v-8 Scamp, was sure there would be a 8 1/4 rear, NOT! It had a 7 1/4 rear also. If this rearend will work behind a 318, surely it must be ok for my slightly modified s/6. Also what gear ratios are available, 3.20 to 1? ripster1@tampabay.rr.com |
| Author: | DusterIdiot [ Wed Aug 29, 2001 10:31 pm ] |
| Post subject: | Re: 7 1/4 rearend |
The following is a list of stock rear ratios for the 7 1/4" from 1965-1989 (yes some 88-89 Dips had square cover 2.76 ratio rears..., and some Dakotas from 87-91 got 3.55's...) In no particular order: 3.90,3.55,2.93,3.23,3.91,2.94,2.76,2.47,2.26 good hunting, -D.Idiot Quote:
: : My 7 1/4 rear end is slap wore out. My : question, is this rear end worth rebuilding? : Thought I got lucky at the boneyard the : other day. Found a 76 v-8 Scamp, was sure : there would be a 8 1/4 rear, NOT! It had a 7 : 1/4 rear also. If this rearend will work : behind a 318, surely it must be ok for my : slightly modified s/6. Also what gear ratios : are available, 3.20 to 1? res0aus2@verizon.net |
| Author: | Craig [ Thu Aug 30, 2001 6:36 am ] |
| Post subject: | Re: 7 1/4 rearend w/3.23 for sale |
I have a 7-1/4 rear end with 3.23 gears in it that I would sell. Came from a 1976 Dart. I'm in Minnesota cfield@ll.net |
